- Joined
- 19 Mar 2007
- Messages
- 715
- Reaction score
- 5
- Country
hi - im putting up aquapanel board in the shower, its the full 2.4m x900mmx 12.5mm boards, only need two...im going to attach battons of 38mm thickness to walls that are soft breeze blocks, i will tile directly onto the aquapanel boards with standard size ceramic tiles...what size screws and plugs should i use...i was thinking of these plugs and screws below..
http://www.screwfix.com/p/fischer-h...w&cm_mmc=AffiliateWindow-_-DeepLink-_-Na-_-Na expensive but very effective in soft blocks
http://www.screwfix.com/p/quicksilver-countersunk-prodrive-10-x-4-pack-of-100/14275
whats the difference between this no 10 screw and the number 12 of the same length ?...is it the thickness of the screw or head size...?
