screws for radiators
30 Mar 2015
Hi All,
Can someone please advise on the plugs and screw sizes I should be using for radiator brackets. I am fixing 1600 x 600 single rads to plasterboard that is glued to blocks.
Thanks in advance.
a friend advised 60mm and number 5. Seems too big based on the discussion above?
oh, and thanks for your input @Steelmasons!
I'd go with what your friend has advised. Need to get through the plasterboard into the block behind
Drill holes where fixing is and make sure the 7mm rawplug is in the block and use 80mm no5 to secure it.
Daniel.
