many thanks for your reply.I've tried loads of different things over the years, but I always seem to end up with a pair of old school-type pencil compasses for a lot of scribes like the ones you've just done. These work quite well for many jobs, but they do have their limitations, such as not being much use for narrow gap scribes (such as when you are shooting a board into a bow legged door casing or scribing skirting to a floor - for which I use a Trend EasyScribe). They are also pretty useless for tasks like scribing tile or laminate round awkward skirting details (a Maco template type tool works better for that).
I recently got myself a modern equivalent of the pencil compass called a Saker scribing tool, but to date I've only used it a couple of times, so I haven't yet formed an opinion as to whether or not it is worth the £25 I paid for it
I ended up using a small piece of wood with a sharp angle on one end and a 20mark for my scribe distance. then use a pencil to "dot" a load of points then joined them up by hand after.
If you mean the chinagraph ? Then it just wipes off with tissue, never had it mark anything.How do you get that off without damaging the surface or having the colour bleed into the material (sometimes a problem with white or very light laminated)?
You can get a fine tip on them with a scalpel, but requires regular sharpening.Surely the lines are a bit thick, though?
I have the Trend Easy Scribe for two particular tasks - scribing skirtings to floors, where for the longer parts it is far faster than a pair of compasses, and for scribing new doors into old casings, where the casing is not straight and where compasses simply won't work (from experience I find that pencil compasses are good where you can place your material to be scribed 20 to 25mm off, but when the gap is 1 to 5mm they simply can't hack it). Other than those two instances I can't think of any task I've undertaken where it would be a "must have" toolI was going to treat myself to a Trend Scribe - but my son-in-law has one and when i used, did not see any advantage over my compasses , so saved the 20+ quid.
Thanks , i will take that off my xmas listI have the Trend Easy Scribe for two particular tasks -
I think i purchased a knockoff of the Saker , purchased from amazon, same picture , same coloured box , orange/black , that i saw on a youtube advert , cant remember which one , but an advert at the beginning, which i normally ignore - so a bit of a impulse buy, and just thought all were the same item, didn't look closely enough , as there is a review about the thumbscrews not locking very wellMine is aluminium and the threads seem OK if a bit on the small side - is yours?
