Long story short - replaced an existing triple shower valve with a scudo from local merchants as couldn't get a replacement cartridge for old one. What they had in stock rather than any other reason for choosing.
Once i had removed tiles etc it was straightforward swap with plumbing in place and roughly matching. Hot & cold inlets and two outputs, valve has three controls. Top for overhead outlet, bottom for siderail shower and middle to set temperature.
Plumbed and turned on - overhead works perfectly. Siderail - no water.
Tried with overhead running and not.
Both outputs worked on previous shower and i have not touched any other connection other than compression joint at shower valve.
I haven't turned cold water pressure fully on, so suppose it could be pressure but would assume neither would work if pressure too low. BTW another triple valve shower in another bathroom works fine so another reason not pressure related?
Any ideas?
Any ideas?
