Seal around Washing Machine Pierced...
11 Feb 2008
Is is dangerous to continue using my washing machine,
I have just seen that between the drum and door, the seal in the middle has a hole in it, its quite a big hole and seems to lead into the machine.
I dont know if water is falling into this when i am washing, also when we put in fabric softner, it goes in one way and we find it on our floor from under the washign machine.
Is it dangerous to keep using this machine or should i report it to my landlady?
This is a picture of the damage in the seal
That hole (slot) looks as though it should be there.
If your machine was leaking you would have water on the floor.
It is supposed to be there......
It is to drain the excess water from the door seal into the sump of the machine. Without it you would have a great big puddle in the fold of the seal..
The hole is designed in. When the machine stops there is usually a lot of water in the folds of the door seal. If this isn't drained away it would all plop out onto the floor when you open the door. Most of it goes down this hole while the door mechanism is timing out.
Did I not say that? I'm sure I did ;) ;) ;)
