hi
i have a franke under mount sink with a granite work top. after over 9 years the sealer which was originally put by the work top manufacturer has cracked and water is leaking when sink in use.
1.do i need a sealer or sealant for underneath. (what type please give name)
2. since i will have limited access underneath i intend to apply the same to the sink from top side which should seal better and stop water from leaking .
3. I am assuming the sealant or sealer has to bond steel with granite.
Thanking you in advance for all the help and advise.
ih
ih
