Hi folks,
A lady of my acquaintance has rcently bought a First floor flat in the Aberdeen area. Built circa 1985 When she bought the flat here was a slight trace of mould on the inside wall near one of the North facing windows which wiped off and hasn't re-appeared.
The construction is brick and the windows are timber frame. There is a gap approx 1/2" between the window frames and the brickwork which has been filled (probably from new) with a brown substance (mastic? hard on the surface but soft & gooey underneath).
I noticed that there's a gap 1/4" between the sealant and the brickwork which I think should be filled.
I was going to scrape out the existing sealant and refill the gap but I'm unsure as to what sealant to use .... Mastic or frame sealant or something else?
Can someone please advise what's best?
