Hello everyone. First post, my window fitters sealed some of the pvc with some kind of sealer the hardens, does anyone know what this is. The sealant outside that meets the brickwork is the flexible rubber stuff but the stuff on the seams on the inside has set solid.
I suspect you might be talking about expandable foam which they use for gap filling and fixing. They then cover with plastic strips and normal white or suitable colour sealant to give it the finish
Thanks for the replies gents, Ken, I’m still waiting on a reply, delmel, definitely not that & Loscie, quite possible. Cheers.
Ken, I just found a few small gaps that need redoing.
