Have started to have to keep topping up the level on a sealed vented system (I think that's what it is - conventional boiler plus cylinder, cylinder vents into cold water tank, boiler and cold in loft, HW cylinder ground floor).
The system runs ok on heating but switching on HW at 430am I can hear the pump struggle when it goes below 0.5bar. I guess when the heating comes on it equalizes the pressure a bit more, but always the HW is where the low pressure causes the pump to whine.
This morning I topped up from 0.5 to 1.0 and checked just now. Was just below 1.0, HW had gone off and CH would have been on and off since. Put the HW on advance and immediately dropped to 0.9. This suggests to me pressure in the HW had been dropping while it was off, by 0.1 per day+ would make sense.
Some valves on the system show some weep - 3 way needs changing I think and pump valves - but that wouldn't impact HW only.
As I can't see any leaks anywhere - other than on the 3 way when I changed the actuator recently and I don't think that's enough to cause this? - does the coil seem the most likely suspect?
System will be about 15 years old now. Stopped using the immersion heated a while ago and water is soft but what else could it be?
Cheers!
Cheers!
