Sealing a firebox
R
richard7761
Below you see a picture of a firebox built onto the left of the chimney stack. Everything left of the vertical yellow dotted line is the firebox in question, everything right of it is more-or-less the chimney stack. The picture is looking sideways into the firebox. The wall on the left is a load-bearing wall seperating a room to the left, on the other side of the wall, and the room I've taken the picture in.
The red dotted lines show where there is an opening from the firebox into the chiney stack.
Now, the green line shows where there was a slate plate. I guess that was used as a kind of seal.
Okay, the original firebox was for an coke burning open fire. But, I just want to have a gas fire.
Anyway, I'm reducing the width of the firebox by one brick length on the right hand side as you look into the fireplace - normally - normal view - (that would be looking from left to right in this picture). This picture is facing the left hand side of the fireplace, so the right hand is towards the viewer, the left hand side away from the viewer.
The right hand side of the firebox (normal view) will, in fact, consist of a brick column right up to the ceiling beams. It willl eventually hold an I beam.
Now, what concerns me is, is there any special work required over the sealing of the firebox?
Do I need to put some kind of plate at the top of the inside of the box, like it was originally? Do I need to spread cement over the insides of the brickwork? Anyone know?
Remember -normal view - is looking left to right in this picture.
House built in 1958. Thanks.
