Sorry if this has been asked a million times.
I have installed a walk in shower cubicle (3 walls and a sliding door).
When I installed the tray, I sealed it with masses of sealant between the wall and the tray, then tiled down to the tray and sealed the joint.
As far as I can tell, I can't see anywhere for the water to ingress at the tray/wall joint it seems pretty well sealed.
Water is getting in behind this joint and appearing as moisture on a grouted joint on the outside of the shower. Where the outer corner of the tray meets the wall if that makes sense. It seems as though the water is getting trapped between the two seals and finding its way to this corner !
Is it possible that it is seeping through the grout ? I had to space out the bottom joints, due to me being a crap tiler !!!! So they are about 4 - 5mm !!
Also, should all the corners be sealed top to bottom in a shower ? Regardless of the type of tiles used ?
