Sealing and waterproofing a very old external brick wall
18 Nov 2007
Gloucestershire
The brick wall at the end of my garden is probably about 200 years old and the faces of the bricks are quite crumbly and powdery. The wall is quite solid in spite of its age but I would like to seal the external surface to prevent further wearing away. Would it be better to use a thinned PVA adhesive or a waterproof sealer? I don’t think that it needs waterproofing as much as stabilising the surface of the bricks. Yes, rebuilding would be the real solution but there would be too many zeros after the number.
Thompsons?
It might be a futile endeavour as its an unsheltered wall. There are probably clear resin type fluids available that can stabilize friable surfaces. Not sure if these are suitable outdoors though.
