Do seal it up, but mould is caused by damp air against a cold surface, draughts actually reduce the mould. Unless they're from the bathroom into the loft of course.
Your mould is because that is cold wall, the heat from the room doesn't really get there and the internal temperature of the wall is too cold compared with the humidity in the room.
