sealing around waste pipe
10 Dec 2013
Bradford
hey I have forgot to seal/ cement up around a cored hole for a 1.5inch waste pipe. Would it be worth going back to the job to do this.
Always worth finish the job off right, issues would be water ingress, creepy crawlies and rodents.
As well as having the pipe securely positioned.
is on the first floor so guessing rodents wouldn't be able to get to it but water ingress could be an issue.
Where is this pipe located? Assume it's a 100mm soil pipe? Always good for your reputation to go back and seal it up and apologise to the customer.
Is this a wind up ? You could have had it done by now ;)
