Hi everyone,
We have had an ongoing problem with the sealant around our new bath and, while I know this has been raised in other topics, I was wondering if anyone thinks mosaic tiles could be at fault.
Basically we had our entire bathroom refitted with mosaic wall tiles (each tile made up of 15x15 squares). Everything has been grouted etc but, after the workers fitted the bath with a standard flexible seal, water was seeping through and the seal was coming away from the wall and tub.
They replaced it with a larger flexible seal but, after a couple of days, that started to come away from the wall too. They then tried a solid plastic seal which seemed to do the job at first but, as before, it started to peel away and water was getting through.
Everytime the workers came back out we were told our mosaic tiles were to blame as the seal didn't have a wholly solid wall to stick too. However, we have our doubts as mosaic tiles aren't that uncommon and we had to ask for them to weight the bath while fitting the first two sealants. We also had to ask for further props under the bath as it was clearly moving when we stood in it, despite claims it was 'rock solid'.
I've read on forums that the Teleseal system is a good bet but I don't want to be spending more if the problem is likely to be the tiles and I need something else.
Sorry for the longwinded explanation but if anyone has any advice that would be fantastic.
Thanks in advance and all the best.
