I have a drain inspection cover located under the (removable) floor of a walk-in cupboard in the bedroom of a basement flat. It covers a T-join between the drains of two separate bathroom/toilets. After having the cover removed to fix a blockage, we now have occasional problems with drain smells in the bedroom. I can see no obvious damage of leaks.
It appeared to have been sealed with something resembling Red Hermatite and was a pig to remove when the blockage was fixed. What is the best material used by the pros to provide a reliable but breakable seal?
As a separate but important issue are there building regulation issues associated with locating an inspection cover in a position like this? I can see no obvious alternative location. The house is a large Edwardian terrace house with the public drains to the front of the property.
Sorry if this is the wrong place for the post but there doesn't seem to be a forum for drains and I can see no threads on this topic in plumbing.
Thanks.
Thanks.
