Sealing Holes into Loft Questions
23 May 2017
Some basic questions on sealing holes to the loft area...
Do I need a specific kind of silicone to seal around the plasterboard and exhaust pipe of my combi boiler?
Can you seal around light fittings and the gaps around the extractor fan hole from inside the loft, is this best done with silicone sealant and should I use a specific type?
I have already sealed my old style loft hatch with rubber seal foam. When it comes to insulating I believe the best method is to bag up insulation and staple to hatch. Is that the case or is there a better method or material to use?
