I've had some problems with condensation in my loft. Seems like the hot water tank in the loft is the culprit. I've covered a WBP ply lid in thick plastic (the stuff you use for stopping weeds coming up) and insulated the tank with space blanket and loft insulation. But when the lid sits on the tank there is still some moisture escaping through a slight gap between the lid and the top edge (aluminium) of the tank, dampening the insulation. Can anyone recommend a gel/sealant/seal to add betweeen the lid and the top of the tank to prevent this leakage? (there is an overflow pipe from the tank to outside so it would not be totally enclosed).
