Sealing new shower tray
18 Jan 2025
Sealing a shower tray
I'm fitting a new shower, 3 walls and a sliding door in a frame. The tray will be tanked to the wall with tanking tape, then tiled. I've read in a few places to seal the between try the tray and tile where the frame meets the wall before adding the door frame so that water can't get behind. That bit I get. What I'm struggling with is after fitting the frame I should seal around the outside of it. But on the bottom corners it will be silicone over the first silicone seal. I keep reading silicone doesn't stick to itself, so is this correct?
One guy I follow says yes. You can apply silicone over silicone.
Here is the test to prove it
I also follow another guy that you may find helpful
Checkout both channels as imo the best ones
Thanks, makes sense because everything says to seal the tray. Then fit the door frame then seal the out side. So confusing with the contradictions
Skillbuilder also made some interesting videos on YouTube about resin trays and common mistakes when fitting.
There is some conflicting opinions and bad practices it seems.
The silicone work in the first video is shockingly bad when viewed on a high definition laptop screen. I do however watch some of his videos.
