I am a DIYer, with no trade qualifications.
I have bought an acrylic bath, and a normal waste set (ie not the banjo overflow type). The waste set has a chrome plughole, (which is supplied with a sort of soft polystyrene gasket that goes between it and the smooth inner surface of the bath), and a screw passes through the metal plughole through into the plastic part underneath. The underneath assembly is supplied with a flexible, but not very compressible, rubber or nitrile gasket.
I have had successful experience fitting this type of waste to kitchen sinks, but those tend to be smooth underneath. The bath is very rough underneath, with what appears to be glass fibre reinforcement, and I don't expect the rubber gasket will be able to make a very good seal against it.
What are people doing about this situation? Would a bead of silicon sealant between the rubber and the bath be a good idea, or might it react against the bath material?
