Sealing with Crown Basecoat
14 Jun 2005
Worcestershire
We've just had a bit of plastering done, and the plasterer recommnded that when it is dry to seal it using a 50/50 mixture of water and emulsion. I think this is pretty standard practice.
We have a tin of Crown Basecoat lying around, can we use this, or is it a "special" kind of paint because it is basecoat?
Phew.
Thank God you sent your message before doing anything.
That sentence has many dangers lurking in it !
Is the full room re-plastered ?
What thickness is the plaster that has been applied ?
What room has been plastered ?
Has the full room been plastered or just patches ?
Sorry, should have given you a bit more info :oops:
We built a fake chimney breast from plasterboard. It's in the living room, and tt's about 1800mm*2300mm on the "front" and has a depth of about 170mm. So not a very big area really.
I wasn't home when the plasterer was there, but the wife says he gave it "two coats". I can have a look tonight, but I don't reckon it was too thick because the surface was smooth that he was applying it too.
Ok.
If you are refering only to the new plaster, then buy Dulux Trade Vinyl Matt.
Follow instructions on this paint.
