Hello,
Approx 5 yrs ago i had pvc double glazing installed to the back of the house from a local company,i requested that i wanted it internally glazed.The company no longer exists.
The problem is that the pane of glass in the frame is misting due to broken down seal.It started with 1 window and now 3 windows.
I had a closer look at the window from outside and inside and noticed that there was no seal on the outside of the window or beading,what the company did is reverse the window so the beading was on the inside and the foam part which you stick to the frame on the outside ,therefore exposing more rain to it .
Is there any such method of fixing this problem, such as some form of beading or is it a matter of replacing all the windows.
Thanks.
Thanks.
