seals on windows
20 Oct 2010
Nottinghamshire
Hi Could any one give me some advise on the correct way to fit 24mm sealed double glazed units to new hardwood doors and windows on a new extension?
I've allready fitted one panel by using doubled sided tape on the inside then put small amount of silicone on the out-side then nailing beading on.
Is this the correct method or should I use a glazing gasket with rubber edges that I've just found on line,which does look like a better finish or is this gasket for pvc windows?
Many Thanks
darren
Many Thanks
darren
The way you've done it is perfectly fine, gaskets are usually used in pvc as there is a groove in the profile to clip it in
