Search behaviour question
27 Aug 2003
London
Given a search which returns several pages of results, it's possible to step through the pages by clicking the on the numbers or > at the bottom.
Result Page: 1 2 3 4 5 6 7 8 9 10 >
As I do, the page number in the URL increases
//search.diynot.com/forum_search.php ... {blahblahblah} ... &page=10
But manually changing the page number in the URL so as to skip forward faster doesn't work - I get
Query failed: Your query contains invalid characters or in invalid search pattern. Please try again.
Why is this? (It's not, BTW, because I've tried to go past the last page of results).
I get a limit of 100. And there's no more pages indicated.
Ah - that's what it is.
That search starts out telling you that it's showing results 1 - 10 of 5923, which does, IMO, imply that you would actually be able to get to all 5923, get to a page showing 1001 - 1010 of 5923, then 1011 - 1020, and eventually page 593, showing 5921 - 5923.
ADMIN - is it documented anywhere that only 100 pages of results are viewable, no matter how many are found?
Is it supposed to be this way?
Scanning over the code, results are limited to the first 1000. At 10/page that is 100 pages. I'm not sure without investigating further why the results are capped at 1000, I will look into it.
It seems to be a common restriction on search engines, including Google.
I expect that to increase performance and reduce strain on the server, the forum search results here are generated and then temporarily cached. When your browser requests a page of results the software doesn't have to query the database again, it just looks at the cache. One reason for restricting the search results to 1000 posts would be to keep the cache storage for each search to a reasonable size. But I may be wrong :p
