Second New Magnaclean leaking from side after service
31 Aug 2015
I have a 28mm magnaclean filter - It was installed six months ago and working - I took of the lid to clean the sludge and tried to put it back - It was leaking and I got a new filter which was installed
Today I drained down the filter and took off the cap - I put it back on and its leaking again from the side valves.
How reliable are these units exactly - I though tthese units could be regularly serviced but this is the second time I have tried to service it and it leaks
The filter sits in an outhouse so is it possible that teh cold has made the cartidge brittle?
Pity, filter catches muck better then almost every filter
When I fit/service magnacleans I suck with water vac and clean the threads and rubber with water and clean wet cloth. Carful dies it when adding any chemical or Inhibitor that it all goes straight in without any spills or over filling.
