Ok, I have some old 1930s windows I would love to keep, but want to insulate a bit better.
Bog standard secondary glazing is an option and can be quite cheap, but often results in a bulky interior timber frame clad in gray aluminium.
The second option is more bespoke secondary glazing but this bumps the cost up a lot apparently.
I had discounted the diy option as being hit and miss. It would probably end up looking amateurish and be ineffective. Similar to clingfilm on the window, but only a bit better.
However, I noticed on all the windows, there is some timber detailing which results in a groove/square edge that runs around each window. This is about 15mm from the window. This is a natural frame to slot in a piece of polycarbonate sheeting. The groove width is only about 4mm wide....but should be just enough.
What are peoples thoughts as to the best way to fix the polycarbonate sheet in place? Would silicone around the 4mm groove and then some on the other side to seal it?
Or should I put some kind of rubber strip around the 4mm groove then seal the polycarbonate sheet in?
View media item 66486
That first groove is what I am talking about, it does not look much but it is just enough to hold something.
If I can get it looking good, I do not see why it would not work and look very nice...
Thoughts?
Thoughts?
