Hello all
I recently posted a question about controlling the bronze pump on my hot water system.
After taking some advice, I purchased a single channel honeywell timer, which I have programmed to work alongside my main DHW / CH controller.
The problem I have is that although the timer is switching the pump off and off ok, I'm not getting hot water at the taps.
I have set the bronze pump to run for about 1 hour in the morning and evening and to come on about half an hour after the boiler has started.
Am I not allowing enough time for the pump to push hot water around the system, or could something else be causing the problem?
I have drained down the system a couple of times to remove sinks etc and as yet, haven't finished plumbing in new facilities. I wonder whether I may have a major air lock somewhere.
Any thoughts?
Steve
Any thoughts?
Steve
