Hi all,
We've noticed our kitchen door out to the garden (typical UPVC job) isn't closing/sealing as well as it should. I can see in one corner there is a gap between the frame seal and the door itself. The hinges have been adjusted quite a bit historically to counter this but there's no further adjustment as far as I can tell. It looks like the hinges have worn and the door has sagged on them - I've had this with most UPVC doors I've owned unfortunately when they get old and have been repeatedly slammed.
It's so bad that we appear to be getting damp coming in now, as the plasterboard at the bottom of the door reveal and the floor tiles at the threshold are showing signs of water damage. I'm guessing it is due to the volume of water getting past the weather seal and finding its way through the bottom of the door frame. (If it's not the door, I've got bigger problems as no idea where else the damp is coming from!)
So, looking at a replacement, I'm interested if there is any particular brand/manufacturer I should be looking for, or specific set of features/technical specifications I should be expecting? I've not had a UPVC door fitted for over 10 years.
I'm thinking of three key areas: security, thermal efficiency (i.e. insulation) and structural strength.
Do I just go with a recommended local fitter and whatever they fit, or is there more science to it? We'll need a replacement window fitted that butts up to the side for half of the height of the door, if that makes any difference.
