I am working on a bodge automated door.
This is the equipment and tools I have...
My door handle is longer than it is wider and it is in the up position while locked, it then must be turned 90 degrees to the right to unlock the door. I have programmed the servo to do this, but my problem falls in attaching the servo to my door.
My original idea was a triangle-like clamp (2 diagonal pieces of plastic attaching (hot glued) to each side of the servo, but I don't know how I would do that without using screws etc.
Any help will be greatly appreciated, thanks in advance
PS: I can't put hot glue on my door.
- A Raspberry Pi (to control the servo, receive commands etc.)
- A 7V servo motor.
- A hot glue gun.
- Some velcro (hook & loop) tape (although it isn't the best).
- Some wire ties and some stationary string.
- Some wire and other electrical equipment (everything required to power a Raspberry Pi and a servo).
