As you can see I'm new to this forum.
I'm trying to secure a safe to a partition wall. The safe will be mounted onto the skirting board of a partition wall. I appreciate its not ideal and concrete would be much better but I don't have the option to do that.
I've used M8 x 75mm coach screws. One of has gone into one of the studs and is pretty solid. The other has just gone into the cavity in the wall and just comes out when tugged on it.
How about if I fill the cavity starting at the back of the stud wall using small amounts of foam filler at a time and build up in layers of 25mm and then fill the final 75mm depth with Ronseal High Performance Wood Filler. Thereby the screw will be driving into the wood filler.
I figured it would need some foam filler to give the wood filler some support. One problem I've found with using things like wood filler to fill deep holes is applying it when it comes in a tube rather than cartridge. Can anyone give me tips on this please?
