Hi I am relaying a floor and want to use screws to hold the floor boards rather than nail them. The floor boards I am using are 20 mm white pine and tongued on two sides and grooved on the other two, The boards are being layed onto 100mm x 100mm Oak joists which are about 500mm centres and I want to know what size and length of screw to use I want to screw them through the tongue counter sunk at an angle is this ok or do I have to go through the top of the board. Also where a board joint is between joists do I need to put a noggin in or will it support OK . Any suggestions most welcome.
