Securing new shower tray
7 Dec 2013
West Midlands
Hi all
I'm about to secure my new shower tray, which is acrylic backed ABS finish, onto 'No More Ply' backer boards.
This is a link for the actual tray
http://www.mx-group.com/products/shower-trays/all-shower-trays/1200x900-lh-optimum--flat-top-ulg/
My query is.... What's the best way to secure it??
Cement based tile adhesive, silicone or sand/cement?
The tray isn't very heavy at all so will need weighing down.
I did try a mortar mix but it didn't work very well.
Any help or advice is much appreciated
Thanks for quick reply. The adhesive I got for the tiles is a cement based one suitable for wet areas (including swimming pools) so I presume it's extremely waterproof. Would this work?
You are bedding tray to a wooden surface, so my preferred choice would be the use of a flexible compound, to address any material movement, this will hopefully prevent damage to tray and damage to bedding bond.
Other opinion may differ, just out of interest what to the manufacturer instruction say?
The instructions say :
Use installation compound adhesive or a suitable adhesive to cover the full area under the shower tray. Apply or trowel to a thickness suitable to allow full adhesive support of the shower tray
Note! Always follow the instructions supplied with an adhesive and do not glue the bottle trap or flexi pipe in position.
7. Place the shower tray onto the wet adhesive ensuring that it is fully supported. Check the level of the top rims only as the shower tray has a built in fall for adequate drainage
Note! Ensure tray is fully stuck down, weight down if necessary, to ensure level and good contact.
8. Remove any excess and allow adhesive to set.
Well it is always advisable to follow manufacturers instructions, as this would not invalidate any guarantee that comes with the tray.
I am not saying that a low strength cement mortar mix or a non-flexible adhesive cannot be used, just it would be my personal choice on a wooden floor.
