What is the best way to securing a shower mixer? The mixer unit has two dog leg screwed connections. I am fitting the shower to a false wall made up of 12mm plywood so can get behind the wall.
I have run plastic pipe up the back of the false wall and secured the pipework with clips. However in the shower instructions it states to connect the mixer unit to a suitable screwed threaded connection and that will hold it in place. In other words the pipe work is taking the weight and supporting the shower mixer in position. Should I use copper connections rather than than plastic pipe and push fit to strenghen it or is there as much easier way to secure the unit?
Thanks for any help
Thanks for any help
