Securit 800l
22 Nov 2011
Lincolnshire
Securit 800l intruder alarm issue
Set my alarm this morning, no issues, just got a call from father in law, called at the house (bear in mind its his first attempt at this) input the code within the entry time.
When leaving the house he rang me to say he has an intermittent tone that will not change to constant tone even when he has left the building, I told him to leave it dis-armed until i arrive home.
All I can think he has done is to try and set the alarm with the entry/exit door open, would this prevent the alarm from going into arm, does this door need to be closed to start the sequence.
No the door does not have to be closed before setting the system (starting the sequence), you are probably correct insofar that Dad may not have set it correctly. How is the system now, is it working O.K. ?
