Security 700l plus reprogramming
12 May 2017
Friend of mine moved into a new house with securit 700l plus fitted but working incorrectly due to changing configuration if the house. I've swapped circuits for entry exit points, but the system won't let me change walk through points with the engineer code or user codes .I have reset the panel with the shorting pins and powered down and back up
Any ideas appreciated
No pretty straightforward enter zone e.g. 43 zone 3 select option e.g. 2 alarm with walk through
That's what i did, but it didn't update the system,couldn't update codes after reset either
What codes are you using, the default ones for that control panel?
Yes, default codes, i had to reset them as we didn't have the engineer code from the previous owner. Its as though its not registering the changes during programming, tbh i think it needs a new panal/board
Yes correct pins as i can now get it into engineer mode, when i try programme zone 3 to alarm/walk through i get the not accepted tone. When i follow the change code steps the 1-4 LED's don't light up as stated in the user manual . i also tried to change code 2 and that wouldn't change either
You know code 2 is set from customer mode ...1234 * 92 ( 4 leds come on ) new code e.g.1066
