Security / Garden Light wiring
7 Feb 2011
Leicester
On my garage wall I have 2 Up / Down lighters with GU10's in, similar to these although wired into a separate stand alone PIR.
http://www.screwfix.com/p/lap-gl-cil26apir-stainless-steel-up-down-wall-light-pir-35w/48480#
The power for the lights is taken from a FCU which is spured from the double socket in the garage.
I would like to add another light fitting to the front of the garage to light the drive way, something like 1 or 2 of these
http://www.screwfix.com/p/unbranded...rolled-spotlight-graphite-230v-w-2500lm/67936
Would I be ok taking the feed from the same FCU protected with a 5A fuse ?
The garage also has its own stand alone CU
I want to make sure the plans are not going to overload the circuit.
Given the max Wattages on each light unit @ 35W x 2 per Up / Down and 75W x 2 Per sensor light I make the total 1.91A
I know that this will be notifiable work but im just running options at the moment
The total demand of existing and proposed new lights would not exceed 2A, so you could fit a 2A fuse but a 5A fuse is acceptable.
I doubt very much this would have any adverse loading affects upon the socket circuit, but always worth asking what type of socket circuit is it, what breaker size and what is the load demand put upon it?
Why do you consider this notifiable work?
I was under the asumption that this would be notifiable as the lighting is:
A) Outside
B) Hard wired to the existing wiring and not plugged into an existing socket
Ill have to check tonight what type of circuit it is and the breaker size but in terms of Load demand, very little else is used in the garage.
Maby the ocasional power tool but thats very few and far between.
I think instead of putting "notifiable" I should have said that I think the work should be carried out by a Part P certified electrician
Curious, as there is no such thing as a Part P certificate. But anyways.
You can do it, you dont need an electrician: registered, certified or otherwise.
No, still not right.
Part P of Building Regulations merely states that work shall be done safely... and to what it applies.
The self-certification schemes are nothing to do with Part P (although they do use the wording) and are irrelevant to all but notifiable work of which there is now very little.
A) Outside
B) Hard wired to the existing wiring and not plugged into an existing socket.
Prior to April 2013, outside electrical work was notifiable, but hard-wired extensions to existing circuits, per se, were not. Since April 2013, even the outside work is not notifiable in England (although it remains notifiable in Wales).
All electrical work has to be undertaken in accordance with Part P of the Building Regs, which essentially just means that it has to be done 'safely'. When work is notifiable (which you proposed work isn't) a registered self-certifying electrician can 'notify' it him/herself (at minimal cost), but anyone 'competent' (everyday sense of the word) can undertake the work if they notify it themselves (usually at considerable cost) to their local authority.
Kind Regards, John
As the circuit is already existing and according to the statutory document not deemed a special location, it would not require to be notified.
//www.diynot.com/wiki/Electrics:part_p:Statutory-Instrument
Part P is a building regulation and is something that must be to complied by law, that includes non-notifiable work.
With regards to the certificate required, there are two that will apply to the work you are discussing.
*An electrical installation certificate
*A minor works certificate
Either of the above can be used to commision the extending of this circuit.
The latter is not as detailed and as time consuming to compose.
Thanks everyone, learn something new every day
So, in your opinion, is what im proposing to do acceptable in terms of running essentially 4 light fittings off of one FCU Spur from the double socket ?
didn't want to start a new thread just for this question....I wanted to fit LED bulbs to the twin PIR light fitting as below
i've read a few comments on here about PIR's not switching on the light fitting when a low wattage bulb is fitted.
I was looking at something like this http://www.amazon.co.uk/Light-Bulbs..._1_1?s=lighting&ie=UTF8&qid=1407485745&sr=1-1
Anyone got any experience of using LED bulbs with PIR's ?
