Security Light- Best Method
3 Apr 2005
Cleveland
Hi, Whats the best method of installing a security light with pir. :idea:
1- Run 3 core cable from unit and wire up to 3 pin plug and plug in or :?:
2- Connect to back of nearest "inside" socket :?:
3- Run to Switched fuse socket then to back of exsisting socket. :?:
Which ever is best method, please could you let me know details.
I have light, i have some 3 core pond cable floating around somewhere or some 1.5 light cable ??
Regards ;)
take 3core flex in thru wall. run it next to a socket. either add a SFCU with 3A fuse, or put a plug with a 3A fuse in on the end and plug it in. do not take a feed direct from the back of the circuit
SFCU = Switched Fused Connection Unit.
Any decent shed will sell you one.
