security light installation.
12 Jan 2005
Wolverhampton
Hi all, have bought a security light with sensor for my drive and was just wandering what is the best way to wire it up.I will be fixing light on garage wall,the garage has a fuse box inside it that currently runs 3 circuits,1 for garage sockets,1 for garage light and 1 for garden lights.
Not sure if i have to treat as a lighting circuit as theres no switch,if not does it need to wired to fuse box or can i put a plug on the of wire and plug into socket???
make sure you adjust the sensor so it doesn't light up when someone walks along the street, or a car passes. (if the sensor has an adjustment)
Hello All
I am not electrically qualified at all , so out of interest, can you lads give me your reasoning :eek: ,
If you were wiring an outside lighting circuit, which, even though the fittings are classed as 'fixed' equipment, and do not require you to do so, but if there were a spare way on a split load c/u , would you connect to the rcd side or not ? (with extra protection and the problems of damp, poor IP rated fittings etc being considered )
This is not a question about work that is being, or is to be done, just a question I would like your opinions on please.
Thanks for your time.
the reason you dont connect it to the rcd side is because its a light
take a house as an example
a light blows and the rcd trips
the rcd turns off all the other lights too.
for the light to have been on it must have been dark, now its toatly dark as all the lights are off, and if you do not have a split load cu (some rcd protected some not) all the sockets go off too
Methinks JC is a Mod...
Well, they think they're Jesus Christ, anyway... :LOL:
