Evening all
Pls can you offer your advice/opinions on the following:
I am aware the work is notifiable.
I am wanting to install a PIR security light for my dettached garage.
My current set up in the garage is a 2 way consumer unit consisting of a 20amp MCB which supplies 4 sockets on a radial and a 6amp MCB which supplies 3 lights all working off 1 switch.
The security light is 500W , am I best wiring this into the exisitng lighting circuit using 1.5mm2 and using a 3 amp FCU or would you suggest I use 2.5mm2 cable and running it from a socket again with a 3 amp FCU ?
Cheers
Ste
Cheers
Ste
