I have a seized 22mm stopcock (stuck in open position) on the HW feed from a Megaflo cylinder to a bathroom. After trying (and failing) to shift it myself, it started leaking from the gland nut, so I called on my home emergency cover to get some professional help to see if a pro could (a) stop the leak and (b) get the valve moving. He fixed the leak (in about 10 seconds) and I asked him to try and get the valve moving. I think he did try but not sure how hard as he may have been worried about it breaking. Anyway, it's still solid.
He suggested I should replace the entire valve with a quarter turn lever one and replace the two others alongside at the same time. That's certainly possible but likely will be quite expensive and it's not really necessary to replace the other two as they are moving freely.
Is it worth trying to crack the valve body and replace it with one taken same from a new one? What are the chances of a new one having exactly the same thread?
TIA
TIA
