Hi
My hot and cold feeds run along the length of the wall I am putting a washing machine and a dishwasher. can I have 2 self cutting valves on each pipe, serving a wash machine and dishwasher respectively?
Yes these valves are rarely satisfactory. With modern push fit plumbing fittings it is quite easy to do the job properly with tees and separate valves as long as you take care to remove any burrs from the cut pipe ends.
