Hi folks
With regards to attaching boxes to steel gate posts etc I normally tap & screw however this can be tedious when doing many fixings. Lately I've been reading up on self drilling screws & my question is which type would suit my needs?
I install electronic security & my up & coming install is to attached Intercom entry panels to steel gate posts & I have seen the below screws which seem to suit the job;
http://www.screwfix.com/p/rawlplug-...el-screws-washer-5-5-x-32-x-3-2mm-pk100/92744
I have read that certain screws can drill up to 1-2mm & others 5mm steel, most steel posts that I encounter are mainly up to 3-4mm, would the above cover from 1-12m steel thickness?
Thank you
ecurran
Thank you
ecurran
