Hi , i want to self level over wall tiles .Im always thinking outside the box .Is it possible .Or what else can i use i want a more modern look they are white 6x6 tiles only 3 rows up .only 2.5 square meters .Ideas please ?
Do we assume that the wall tiles aren't straight and level. If that's the case, then you would better off removing them, and then getting plasterer to replater the wall.
Or are you thinking of just tiling over the existing tiles. You can do that, but you'd then have a wide lip at the top of the tiles that would look odd.
