- Joined
- 7 Oct 2012
- Messages
- 41
- Reaction score
- 1
- Country
My garage floor is an old concrete scree which is very uneven and with nobbly ridges and bumps. I wanted to level it so...
I used Setcrete Universal Floor Levelling compound in 20kg bags. I used the official Setcrete High Performance Acrylic primer with it. I primed thoroughly and left it plenty of time overnight and was very dry. I used 8 bags and I believe kept it within the specified 3-6mm. I think at times it may have gone slightly over 6mm.
The finish is soft. I can dig my finger nail into it and pull out bits of the compound. If I knock it with my knuckles, it is solid. It's just quite soft so could be easily damaged with sharp and heavy things. I have no confidence in it as a garage floor currently. It has some minor cracking in it in places and I did struggle with getting rid of all bubbles despite using a spiked roller. Maybe it was the heat we did it in over the weekend being probably high 20s. It's a small garage only about 3.5 x 4.5m. We had problems with getting all of the lumps out of the mix. I'm not sure if that's because the product had been sat for a while.
Should I have used a Latex based one? This is just a universal one with water I believe.
To harden it up but still use the now smooth and level floor, could I apply anything else to it like an expoxy paint or something? Or shall I buy some rubber tiles and be done with it. I just don't want it to start breaking up.
