I've read the wiki and a few posts regarding usinig SLC but am a bit confused so would like to confrim a few things.
I'm in the process of replacing my floor (1930s house, ground floor). The previous owner had removed the chimney and so the floor consited of a badly patched concrete area where the chimney had been + knackered floorboards. I will be replacing the floorboards with 22mm T&G chipboard - unfortunatley I didn't read this forum before buying these boards so didn't realise these are spawn of the devil & I should have got plywood instead . I plan to patch up the conrete area so that it is level with the boards. So my questions are:
1) Should I use SLC over the boards/ concrete to gain a completely level surface? I will be laying a floating laminate floor on top - could I get away with just using an underlay? Is SLC OK on chipboard?
2) When using SLC what is the best way to seal up the gaps/holes - ie round the edge of the walls & round the radiator pipes? I thought of expanding foam + silicon sealent.
3) I'm putting in a DPM to prevent condensation problems as I'm fitting Kingspan type insulation between the joists - what is the best way to seal this against the walls. Also what should I do over the ex-chimney area?
Hope you can help!
Hope you can help!
