I'm planning to replace carpets downstairs with quality laminate flooring.
The concrete base is not brilliant, so it looks like I'll need to use self levelling compound.
The living room is fairly large (8m x 4.5m) so according to the flooring instructions I need to use door bars where it joins other rooms rather than lay one continuous mass of flooring.
I'm wondering if I can therefore lay SLC in one room, block it where the door bar will go, let it dry, then do another room. This will mean I can transfer furniture between rooms rather than have to clear the entire downstairs, which will be a nightmare.
Is this not advisable for any reason? Will it be hard to get the levels consistent between rooms?
