Self levelling on part of floor
28 Mar 2011
London
Hi, looking to re-tile the galley kitchen floor which has a plywood subfloor. The kitchen units can't be moved so I'm only going to tile up to the unit legs.
Part of the floor (maybe 50cm x 30cm) by the door dips by about a 1-1.5cm. I was going to lay ditra but given the slope in that area, is it possible to lay self levelling in just that area to build up the height or does the whole surface need self levelling put down?
If the entire area does need self levelling, what can I use to act as a dam to stop the self levelling running all the way under the units to the walls and where there is an expansion gap between the ply and the wall?
