Hi Guys,
I tried fitting an under counter water filter kit (http://www.screwfix.com/p/water-filter-kit/14306). Got everything installed and then as the last step I tightened the self-piercing value which seemed to go ok. When I turned the water back on nothing is coming out of the water filter tap. I read on a thread that you need to back the valve off a bit until you get a flow. It doesn't mention this in the instructions but I tried this nevertheless but after undoing the value a fair bit there was still no flow and a slight leak so I tightened it back up.
I then removed the tube from the self-piercing valve and slowly backed the valve back off again and nothing came out. Could it be the valve is faulty or am I missing something or made a mistake?
If it is a faulty valve and I get it replaced can I reuse the hole that the self-piercing valve made or do I need to create a new one and somehow block the old one?
Thanks,
Tim.
Thanks,
Tim.
