With a semi gravity system (gravity H/W) and pumped heating, and the heating having an anti-gravity valve after the pump, is there 2 vent pipes (1 for H/W and 1 for HTG) and 2 cold feeds?? Usually semi-gravity systems have 4 tapping-boilers don't they??
Thanks for your info.... I guess as long as the anti-gravity valves are after the pump then it would have been fine with only HW on (ie in summertime).
If you replace a HW cylinder or a boiler on a semi gravity system can you still have the HW gravity, and just use a thermo mechanical stat (ie Drayton Tapsat) or do you need a cyl stat and MV ???
I see, a new boiler would mean a cyl stat and a 2port (MV) for the hw circuit as well as the HTG circuit, but a new cylinder only then a tapstat would be allowed.
