Hello
So I've made a slight mistake on my AV setup when I refurbished my house.
Originally I was going to use Virgin Media so had a cable run from the front of my house under the floor to my Zero Node under the stairs.
However ive now got BT Infinity with a YouView Box.
The problem is that it needs to be attached to a TV Ariel and there is no TV Ariel going into the Zero Node under my stairs.
The mistake we made was to have the TV Ariel cable come down through the wall behind the TV (which is on the opposite wall behind the plasma TV which is also mounted on the wall).
There is an ethernet cable running and HDM cable running from behind the TV to the Zero Node I was thinking perhaps I could send the Coxial single over it to the you view box.
Hmm I appreciate I may not have explained this very well quite had too.
I think the only other alternative is to use existing cable to install a free Stat then install a AV Receiver just to switch between the two. As the Youview box will still work just with the Sky channels.
